Help? for clever people only! :)
the following data is to long for virtual device... i need to grab just the last value id:0 with th rfid tag data so i can trick hc2 into using my zipato rfid reader if value = foo!
HC2 = Net.FHttp("127.0.0.1",11111);
response, status, errorCode = HC2:GET("/api/devices?id=523");
--jsonTmp = string.sub(response, 0, 0) -- Need to remove first and last brackets
jsonTbl= json.decode(response)
fibaro:debug(jsonTbl.properties.userCodes);
[{"code":"","id":1,"status":"available"},{"code":"","id":2,"status":"available"},{"code":"","id":3,"status":"available"},{"code":"","id":4,"status":"available"},{"code":"","id":5,"status":"available"},{"code":"","id":6,"status":"available"},{"code":"","id":7,"status":"available"},{"code":"","id":8,"status":"available"},{"code":"","id":9,"status":"available"},{"code":"","id":10,"status":"available"},{"code":"","id":11,"status":"available"},{"code":"","id":12,"status":"available"},{"code":"","id":13,"status":"available"},{"code":"","id":14,"status":"available"},{"code":"","id":15,"status":"available"},{"code":"","id":16,"status":"available"},{"code":"","id":17,"status":"available"},{"code":"","id":18,"status":"available"},{"code":"","id":19,"status":"available"},{"code":"","id":20,"status":"available"},{"code":"","id":21,"status":"available"},{"code":"","id":22,"status":"available"},{"code":"","id":23,"status":"available"},{"code":"","id":24,"status":"available"},{"code":"","id":25,"status":"available"},{"code":"","id":26,"status":"available"},{"code":"","id":27,"status":"available"},{"code":"","id":28,"status":"available"},{"code":"","id":29,"status":"available"},{"code":"","id":30,"status":"available"},{"code":"","id":31,"status":"available"},{"code":"","id":32,"status":"available"},{"code":"","id":33,"status":"available"},{"code":"","id":34,"status":"available"},{"code":"","id":35,"status":"available"},{"code":"","id":36,"status":"available"},{"code":"","id":37,"status":"available"},{"code":"","id":38,"status":"available"},{"code":"","id":39,"status":"available"},{"code":"","id":40,"status":"available"},{"code":"","id":41,"status":"available"},{"code":"","id":42,"status":"available"},{"code":"","id":43,"status":"available"},{"code":"","id":44,"status":"available"},{"code":"","id":45,"status":"available"},{"code":"","id":46,"status":"available"},{"code":"","id":47,"status":"available"},{"code":"","id":48,"status":"available"},{"code":"","id":49,"status":"available"},{"code":"","id":50,"status":"available"},{"code":"","id":51,"status":"available"},{"code":"","id":52,"status":"available"},{"code":"","id":53,"status":"available"},{"code":"","id":54,"status":"available"},{"code":"","id":55,"status":"available"},{"code":"","id":56,"status":"available"},{"code":"","id":57,"status":"available"},{"code":"","id":58,"status":"available"},{"code":"","id":59,"status":"available"},{"code":"","id":60,"status":"available"},{"code":"","id":61,"status":"available"},{"code":"","id":62,"status":"available"},{"code":"","id":63,"status":"available"},{"code":"","id":64,"status":"available"},{"code":"","id":65,"status":"available"},{"code":"","id":66,"status":"available"},{"code":"","id":67,"status":"available"},{"code":"","id":68,"status":"available"},{"code":"","id":69,"status":"available"},{"code":"","id":70,"status":"available"},{"code":"","id":71,"status":"available"},{"code":"","id":72,"status":"available"},{"code":"","id":73,"status":"available"},{"code":"","id":74,"status":"available"},{"code":"","id":75,"status":"available"},{"code":"","id":76,"status":"available"},{"code":"","id":77,"status":"available"},{"code":"","id":78,"status":"available"},{"code":"","id":79,"status":"available"},{"code":"","id":80,"status":"available"},{"code":"","id":81,"status":"available"},{"code":"","id":82,"status":"available"},{"code":"","id":83,"status":"available"},{"code":"","id":84,"status":"available"},{"code":"","id":85,"status":"available"},{"code":"","id":86,"status":"available"},{"code":"","id":87,"status":"available"},{"code":"","id":88,"status":"available"},{"code":"","id":89,"status":"available"},{"code":"","id":90,"status":"available"},{"code":"","id":91,"status":"available"},{"code":"","id":92,"status":"available"},{"code":"","id":93,"status":"available"},{"code":"","id":94,"status":"available"},{"code":"","id":95,"status":"available"},{"code":"","id":96,"status":"available"},{"code":"","id":97,"status":"available"},{"code":"","id":98,"status":"available"},{"code":"","id":99,"status":"available"},{"code":"","id":100,"status":"available"},{"code":"","id":101,"status":"available"},{"code":"","id":102,"status":"available"},{"code":"","id":103,"status":"available"},{"code":"","id":104,"status":"available"},{"code":"","id":105,"status":"available"},{"code":"","id":106,"status":"available"},{"code":"","id":107,"status":"available"},{"code":"","id":108,"status":"available"},{"code":"","id":109,"status":"available"},{"code":"","id":110,"status":"available"},{"code":"","id":111,"status":"available"},{"code":"","id":112,"status":"available"},{"code":"","id":113,"status":"available"},{"code":"","id":114,"status":"available"},{"code":"","id":115,"status":"available"},{"code":"","id":116,"status":"available"},{"code":"","id":117,"status":"available"},{"code":"","id":118,"status":"available"},{"code":"","id":119,"status":"available"},{"code":"","id":120,"status":"available"},{"code":"","id":121,"status":"available"},{"code":"","id":122,"status":"available"},{"code":"","id":123,"status":"available"},{"code":"","id":124,"status":"available"},{"code":"","id":125,"status":"available"},{"code":"","id":126,"status":"available"},{"code":"","id":127,"status":"available"},{"code":"","id":128,"status":"available"},{"code":"","id":129,"status":"available"},{"code":"","id":130,"status":"available"},{"code":"","id":131,"status":"available"},{"code":"","id":132,"status":"available"},{"code":"","id":133,"status":"available"},{"code":"","id":134,"status":"available"},{"code":"","id":135,"status":"available"},{"code":"","id":136,"status":"available"},{"code":"","id":137,"status":"available"},{"code":"","id":138,"status":"available"},{"code":"","id":139,"status":"available"},{"code":"","id":140,"status":"available"},{"code":"","id":141,"status":"available"},{"code":"","id":142,"status":"available"},{"code":"","id":143,"status":"available"},{"code":"","id":144,"status":"available"},{"code":"","id":145,"status":"available"},{"code":"","id":146,"status":"available"},{"code":"","id":147,"status":"available"},{"code":"","id":148,"status":"available"},{"code":"","id":149,"status":"available"},{"code":"","id":150,"status":"available"},{"code":"","id":151,"status":"available"},{"code":"","id":152,"status":"available"},{"code":"","id":153,"status":"available"},{"code":"","id":154,"status":"available"},{"code":"","id":155,"status":"available"},{"code":"","id":156,"status":"available"},{"code":"","id":157,"status":"available"},{"code":"","id":158,"status":"available"},{"code":"","id":159,"status":"available"},{"code":"","id":160,"status":"available"},{"code":"","id":161,"status":"available"},{"code":"","id":162,"status":"available"},{"code":"","id":163,"status":"available"},{"code":"","id":164,"status":"available"},{"code":"","id":165,"status":"available"},{"code":"","id":166,"status":"available"},{"code":"","id":167,"status":"available"},{"code":"","id":168,"status":"available"},{"code":"","id":169,"status":"available"},{"code":"","id":170,"status":"available"},{"code":"","id":171,"status":"available"},{"code":"","id":172,"status":"available"},{"code":"","id":173,"status":"available"},{"code":"","id":174,"status":"available"},{"code":"","id":175,"status":"available"},{"code":"","id":176,"status":"available"},{"code":"","id":177,"status":"available"},{"code":"","id":178,"status":"available"},{"code":"","id":179,"status":"available"},{"code":"","id":180,"status":"available"},{"code":"","id":181,"status":"available"},{"code":"","id":182,"status":"available"},{"code":"","id":183,"status":"available"},{"code":"","id":184,"status":"available"},{"code":"","id":185,"status":"available"},{"code":"","id":186,"status":"available"},{"code":"","id":187,"status":"available"},{"code":"","id":188,"status":"available"},{"code":"","id":189,"status":"available"},{"code":"","id":190,"status":"available"},{"code":"","id":191,"status":"available"},{"code":"","id":192,"status":"available"},{"code":"","id":193,"status":"available"},{"code":"","id":194,"status":"available"},{"code":"","id":195,"status":"available"},{"code":"","id":196,"status":"available"},{"code":"","id":197,"status":"available"},{"code":"","id":198,"status":"available"},{"code":"","id":199,"status":"available"},{"code":"","id":200,"status":"available"},{"code":"","id":201,"status":"available"},{"code":"","id":202,"status":"available"},{"code":"","id":203,"status":"available"},{"code":"","id":204,"status":"available"},{"code":"","id":205,"status":"available"},{"code":"","id":206,"status":"available"},{"code":"","id":207,"status":"available"},{"code":"","id":208,"status":"available"},{"code":"","id":209,"status":"available"},{"code":"","id":210,"status":"available"},{"code":"","id":211,"status":"available"},{"code":"","id":212,"status":"available"},{"code":"","id":213,"status":"available"},{"code":"","id":214,"status":"available"},{"code":"","id":215,"status":"available"},{"code":"","id":216,"status":"available"},{"code":"","id":217,"status":"available"},{"code":"","id":218,"status":"available"},{"code":"","id":219,"status":"available"},{"code":"","id":220,"status":"available"},{"code":"","id":221,"status":"available"},{"code":"","id":222,"status":"available"},{"code":"","id":223,"status":"available"},{"code":"","id":224,"status":"available"},{"code":"","id":225,"status":"available"},{"code":"","id":226,"status":"available"},{"code":"","id":227,"status":"available"},{"code":"","id":228,"status":"available"},{"code":"","id":229,"status":"available"},{"code":"","id":230,"status":"available"},{"code":"","id":231,"status":"available"},{"code":"","id":232,"status":"available"},{"code":"","id":233,"status":"available"},{"code":"","id":234,"status":"available"},{"code":"","id":235,"status":"available"},{"code":"","id":236,"status":"available"},{"code":"","id":237,"status":"available"},{"code":"","id":238,"status":"available"},{"code":"","id":239,"status":"available"},{"code":"","id":240,"status":"available"},{"code":"","id":241,"status":"available"},{"code":"","id":242,"status":"available"},{"code":"","id":243,"status":"available"},{"code":"","id":244,"status":"available"},{"code":"","id":245,"status":"available"},{"code":"","id":246,"status":"available"},{"code":"","id":247,"status":"available"},{"code":"","id":248,"status":"available"},{"code":"","id":249,"status":"available"},{"code":"","id":250,"status":"available"},{"code":"","id":251,"status":"available"},{"code":"","id":252,"status":"available"},{"code":"","id":253,"status":"available"},{"code":"","id":254,"status":"available"},{"code":"","id":255,"status":"available"},{"code":"\u008F\u00F1\u00C2T*\u0000\u0001\u0004\u0000\u0000","id":0,"status":"available"}]
6 answers to this question
/emoticons/default_icon_eek.gif" alt=":shock:" /> I thought that was not compatible  RFID Zipato with HC2
Sorry for my bad English...
    i can see part of the api that changes as the user enters the code on the device... so my thinking is
    if code = the same as user just entered on api then = true
    if not then do nothing...
    [ Added: 2015-01-15, 13:13 ]
    it is just that the table that is returned is HUGE and i am unsure how to approach checking the calue of id:0 right at the bottom of the table!
    [ Added: 2015-01-15, 13:16 ]
    ahh u might have just sussed it...
    had the string.sub before the decode not after! doh!
    I'm not a good programmer
    It would be also interesting for me to find a solution.....
    unless u force a blank value back to the api it will not work... i managed to get the data i wanted... unless i used 1 tag for arming and 1 tag for disarming that would work as the value would be different.
    [ Added: 2015-01-15, 13:47 ]
    but fibaro will support this device in the next release
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> isn't that right Fibaro
    yes... I not believe
    got it working with vera and using the api made it usable under fibaro... that will do me for now... keypad only rfid tags not working yet
