Natural Gas Detector - Z-wave or Retrofit with Z-wave module
Guest chaicka
I am thinking of installing natural/flammable gas detector to safe-guard against gas leaks since the gas pipes run inside the false ceilings across the house.
Is there z-wave based natural/flammable gas detector available in the market?
Or do we get a normal one and connect to a z-wave module (eg. universal binary module)?
Thanks.
chaicka, there are not many Z-wave enabled solutions, UBS should do the work just fine when connected to any with relay output.
