HCL and PHILIO 3in1
Hi all, I'm trying to include the philio 3in1 sensor to the HCL zwave network but I'm not even able to see data coming in on the small log textarea..from what I saw on the vesternet website it seems that the sensor is recognized and supported, only the light sensor shouldn't work. I need the temperature one so I should be ok..the only problem is that I can't include it..
Cheers,
ALF
HCL 3.593
[ Added: 2015-01-17, 12:50 ]
Ok, it was my fault. I did not exclude the device properly. Now it works but, even if I see the temp indicator, it is recognized as a motion sensor..no temp sensor at all
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> ideas?
