Home Energy Meter DSB28-ZWEU
Just added Home Energy Meter DSB28-ZWEU E2
Is it still useless since the 2013?
The only thing I can get - total power consuption, not by phases.
All parameters are dead, some controls are out of places.
11 answers to this question
i have got the same problem. also made a topic.
it has to do wiht the parameter settings!
Def461,
Yes.
/emoticons/default_icon_confused.gif" alt=":-?" />
per bugzilla 0001089 : Acknowledged ..
has duplicate 0001710 closed a.socha HC2 v3.xxx Aeotec HEM2 cannot change parameters
has duplicate 0001714 closed a.socha HCL v3.xxx Aeon Labs Energy Meter (2nd Edition) - DSB28-ZWEU not supported correctly
has duplicate 0001868 closed m.roszak HC2 v4.xxx AeonLabs Clamp Power Meter - three clamps Second Edition - AEO_HEM3_2E Not reporting energy usage
has duplicate 0001984 closed a.socha HC2 v4.xxx No consumption measure with AEON / AEOTEC DSB28 (Home Energy Meter 2e Edition).
has duplicate 0002018 closed m.roszak HC2 v4.xxx AEON Labs enery switch does not show comsumption.
has duplicate 0002071 closed m.roszak HC2 v4.xxx aeonlabs DSB28- ZWUS 2nd edition - nie pokazuje wartości
has duplicate 0002158 assigned m.roszak HC2 v4.xxx Aeotec Home Energy Meter (2nd Edition)
related to 0001750 closed a.socha HC2 v3.xxx AEON Home Energy Meter 2 - nie działa w HC2
    Cool!
    Mine (DSB09104-ZWEU) is working on version 3.600 and earlier versions. Had to flash it with Aeotec's 3.64 firmware to get it working.
    I have a 3 clamp version but 'reflashed' it with 1 clamp version, without any problems. (I don't need 3 phase measuring)
    I don't know if the 2nd edition has to be handled the same way?
    Lambik, You are correct of course, I had the first Ed and it worked previously. Foolishly I gave it away when i got the 2nd Ed which doesn't have a USB port, and cannot be flashed.
    I think it is OTA ready for firmware updates, but that doesn't appear to be a thing anymore ..
    I've tried the first Ed settings, parameters and just about everything to try and get it to work, subsequently given up on getting this working at this stage ..
    NVM, it will be supported at some stage I'm sure.
    Cheers,
    al.
    Sorry, but I really need THREE clamps
    The thing I am trying to point out is that I flashed the device. So maybe you can try to flash it with the 3 clamps firmware.
    I don't not know if this will work, but it can maybe worth trying?
    [ Added: 2015-01-19, 22:47 ]
    I did the same Lambik... flashed a 2 clamp to 1
    Did it work?
    [ Added: 2015-01-19, 22:51 ]
    Okay, sorry, didn't know that....
    I've 2 clamps with 3.67 firmware version but it never worked on 4.x HC2.
    On the Aeon Lab site I can't find where download the 3.67 , I see only the 3.64.
    Have you ever seen this more recent file?
    I'v got Home Energy Meter DSB28-ZWEU E2 &fibaro 4.040v HC2
    Device shows KW and KWh on A,B,C and summary ABC phases but ... 3 times more than should be?? Why? Dont know... any Ideas?
    At that moment DBS28 is not aded to energy statistics. Fibaro has knowledge about these issues... Maybe in next upgrades
    I have the HEM2 2 phase FW1.7 and i get reports on total and seperate phases, but i only get a report every 52 minutes.
    Does anybody know how to change that?
    I tried it with parameters 111, 112, 113 but when i change them, it looks like they are not send to the device.
    the parameters are: (standard)
    111: 360
    112: 720
    113: 720
    but that still doesn't match the 52 minutes
