Bamsefar 13
There is definitely a problem with sliders in VDs (Virtual Device)....
Apart from change in syntax for control of the slider - somehow - the behavior is clearly not acceptable. The attached VD has a label, a button, and a slider.
- If one drags the slider to a position, say about 35, then push the button, it will say which value the slider is at in the label.
- The slider is reset to visually zero within a second or two - but as I wrote push the button, the correct value is shown in the label.
I have also noted that if you send, in version 3.590, a value of "1.20" - it will accept this, however int version 4.031 it will well accept it maybe but nothing shows. This MIGHT be related to the same error as above - I can not say since there are NO debug possibilities in this software (which is a shame).
