Reduce visible temperature sensors in HC2 console?
Hi all,
In most rooms of my house I have Fibaro smoke detectors installed, which also have the capability of providing temperature information.
However, I also have a Fibaro motion detector sensor installed in the very same rooms, which also have the capability of providing temperature information... so in my HC2 console I now see two temperature sensors displayed in a single room, and I am wondering if I could disable / remove or consolidate both to only one being displayed.
Right now the console looks a bit crowded because of the duplicates
I already found that with removing one temperature sensor, it actually removes the whole Motion sensor.
You can hide the temperature-sensor in the advanced settings:
"The device is hidden in the system" See attachment
Just be sure not to hide the one that shows in the room. Otherwise you can't open "Rooms" anymore. It's a known bug.
    Hi both,
    Thanks a lot, I overlooked this simple setting...
