Satel integratie. Help me
Can any one help me. I have software 4.31 and a satel alarmsystem. But now i have a triangel and now it says there is now block whit the name fibaro. But i have one block fibaro and a zone fibaro. There is no download display when i download the settings.
Sorry about my bad english.
6 answers to this question
Not sure if 4.x is different, but I also have a warning about missing Fibaro partition which is not true - I do have partition named Fibaro and also zone named Fibaro, did Satel reconfiguration several times and the warning is still there.
    My to. I hope they fix this problem. Before the update There was no trouble. And when i download the setting i say a dowbload display. Now i see nothing. I hope that it will be fixt.
    I am on 3.600 and still have this warning, however all satel devices are visible and accessible from HC2.
    According to the change log for 4.032 satel fix is not in :/
    Made Satel integration on my HC2 v4.032 today and no warning about Fibaro zone/partition was displayed. Actually all seems to work fine.
    Oke and what did you do exactly. And your setting in satel?
    nothing particular, settings from satel ETHM1 are: port, integration: Yes, coding: No
