Hi
One of my Fibaro Motion sensors doesn't seem to be updating the LUX value correctly.
Does anyone know how can I trouble shoot this to see if its a hardware or software issue, prior to looking to return the item?
S.
Hi
Try changing parameter 40 to 5 lux, this is the value I use to set. And wake up your device manualy.
Bye!
Hi
S.
I think the inclusion process did not finish successfully.
You can try the following options:
- soft reconfigure
- reconfigure
- remove and add
- remove, reset sensor and add
