I tried google and this forum, I found some topics but nothing complete.
My goal is to make a button where i can trigger several actions.
for example:
leave the house
- roller shutter close, temperature reduction, all lights off.
Programming in blocks is not the issue, but setting up a virtual device is.
1/ what should i enter in the IP address section? I assume the device IP
2/ same as above but regarding the port number
3/ what kind of code should i use to change a variable
all info regarding virtual devices is welcome.
5 answers to this question
Why create a virtual device?
If the hallway of the house is using a fibber dimmer you could activate scene activation in this dimmer.
This scene activation could then be used so eg. triple click on the button execute the actions
- Roller shutter close
- Temp Reduction
- All lights off
    thank you for the idea, i will keep it in mind.
    but i would like to trigger the scene's on my mobile device, when i'm not at home.. or to lazy to walk to the switch
    Hi Michael,
    I've created scenes which changes my variables on my HCL. Then I use virtual devices to run these scenes. Se this
    . Hopefully it will help you achieve what you want to do.
    hi Henrik,
    Thank you for this information.
    I would like to control the IPCAM over the virtual device. There are option for control directly in camera settings, but I would like to use other commands to activate recording etc.
    When I enter this into browser "http://192.168.1.13:88/cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=XXX&pwd=XXX" with correct user ID and pswd, camera responds and move. When I use the same command within the virtual device, nothing will happen.
    Is there any guideline how to send command over the virtual device to other IP controlable devices? I used also " get /cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=XXX&pwd=XXX" with propper IP and port in virtual device properties.
    Help is very appriacated. Thanx
