alkorsi 1
Hi all,
I really would need your help. I have a keyfob with 4 keys. If key 1 is pushed a global variable is set to "On" that triggers a scene to arm some window sensors. If key 3 is pushed this global variable is set to "Off" that triggers a scene to disarm these sensors. For the first time it seems to work as expected but all following pushes (doesn´t matter if 1 or 3) don´t set the global variables accordingly and therefore arming and disarming doesn´t work. Do I have to "close" or "end" this LUA based scene anyhow at the end? Or is something else wrong?
here is my code:
%% properties
133 sceneActivation
%% globals
local id= 133; -- Doppeltaster
local name = fibaro:getName(id);
fibaro:debug(name);
ActiveSceneId =tonumber(fibaro:getValue(id, "sceneActivation"));
fibaro:debug(ActiveSceneId);
if ( tonumber(fibaro:getValue(id, "sceneActivation")) == 11)
-- button 1, single press - Activate AlarmModus Stufe 1
then
fibaro:setGlobal("AlarmModus", "An");
fibaro:setGlobal("AlarmModusStufe1", "An");
if ( tonumber(fibaro:getValue(id, "sceneActivation")) == 31)
-- button 3, single press - Deactivate AlarmModus Stufe 1
then
fibaro:setGlobal("AlarmModus", "Aus");
fibaro:setGlobal("AlarmModusStufe1", "Aus")
local alarmModus = fibaro:getGlobalValue("AlarmModus");
fibaro:debug(alarmModus);
local alarmModusStufe1 = fibaro:getGlobalValue("AlarmModusStufe1");
fibaro:debug(alarmModusStufe1);
thanks and cheers,
alkorsi
4 answers to this question
