HI guys,
Im from Brazil. Im starting in home automation =))
I bought HC2, dimmers, roller, relay 2x15.w, to start my home automation..
First i bought few equips to test in my house..
I started with some dimmers in on/off switch for fluorescent lamps.. around 50w only =)
I want full system.. cameras, motions, doors, locks, audio, video, AC, all that can be controlled by fibaro system..
so i will posting here all my process =)
Ty,
[ Added: 2015-01-22, 01:12 ]
Ah..
a first problem =) im using dimmers in on/off switch for fluorescent lamps.. but when i turn off this still flicking.. so i got a test and checked that 55v are sending to lamp.. for this reason the lamp are flicking..
After some search on internet.. i discovered that i need put parameter 10 to 0.. so this still same.. =((
any sugestion ? i need use bypass for each dimmer?
Ty!
[ Added: 2015-01-23, 00:28 ]
how about blasters ? which do i buy for best config/performace ?
i have tv, home, ac... few anothers IRs..
