I have a 12v supply to my Fibaro RGBW controller. I've added it to my HC2 but cannot get the lights to turn on and off via the web ui.
If i plug a traditional manually remote controller in to the lights they work fine.
What could be wrong ? The controller is pretty much default params and settings.
I've tried two fibaro RGBW controllers just to be sure nothing is wrong with one of them.
I was running HC 4.19 firmware
Cheers
Can you make a picture of your attached device?
Like boomx said, a wiring diagram + screenshot of web gui + photo of your setup may help us determine what's wrong...
Because I am a wicked boy
/emoticons/default_icon_smile.gif" alt=":-)" /> I am going to be, well, wicked: have you read the fine manual?
I know when you buy these second hand, those sheets of paper are often missing
Sanity check - have you bridged the power from the power supply to the lights?
I'd like to add... Beware, the outputs are single ended.
