I'm just wondering if anyone else has had this issue. Yesterday I came home to a broken Motion Sensor on the floor, the cleaner had been in and I can only assume she banged the door which caused the sensor to fall. I noted how loose it was when installing and the problem is exacerbated when you use a screw to mount the holding bracket as it seems to pull the arms from the ball.
I understand that this is to allow it to detect tremors, a feature I have no interest in personally and the closing of a door generally triggers the tamper alarm, and I would imaging mounting over doors is quite common.
Does anyone else feel the arms and hold of the ball in the mount is too loose or is it just me ?
  • 3 weeks later...
Feels pretty strong in my case. Maybe the clamp was bent?
It takes about twice the force to tap the spacebar on my computer, to dislodge the sensor. Not very much force if you ask me...
I see only one option. The option that fixes cars and repairs trains: duct tape!
Guest Kuuno
is the original screw used? sometimes installers use their own screws and they have bigger head than original and makes holding the sensor weaker...
That's great thinking! Really! I can indeed see how that could lead to problems... And in my case it's partly true, but the head of my screw is the same. I actually thought about the weak clamping as soon as I opened the package.
Nevertheless... nice thinking!
Guest chaicka
Over here, it seems the Fibaro motion sensors are supplied with M6 tapered screws which I find too big (it does not sit 100% flush into the tapered mould of the plastic clamp). I had to source for slightly smaller than M6 tapered screws which flushes well with the tapered mould and the plastic clamp seems having a better grip of the motion sensor.
