HCL + Smoke Sensor + single beep
I´m new on Fibaro and switching from a house Management System provided by a german electrical company called RWE Smarthome.
My HCL with Software Version 3.593 has 7 smoke sensors to manage and I have 2 question:
1. it seemed that I received 6 smoke sensors Version 2.5 and 1 smoke sensor v 2.1. Is there any way to update the smoke sensor to Version 2.5?
2. 1 sensor is installed in the same room like the HCL. The sensor beeps (single beep) sometimes. Where can I find a hint on this issue? What caused the sensor to beep?
Thank you very much!
Francisco
1. No
2. Seems to be a connection issue. Try to reset and re-include it
    I did that before. HCL is about 3 meters away
    [ Added: 2015-01-23, 20:57 ]
    maybe I found the problem......
    the antenna "holder" inside the HCL is broken. The little piece where you attach the antenna is loose... I solded it to the pieced left on board. Maybe I do have a antenna Problem
    [ Added: 2015-01-23, 21:22 ]
    one more question:
    Associations.
    What does "Set up" and "View" mean?
    Setup: I configure p. e. 1 master smoke sensor and match all others to him, so the configuration will be applied to the others?
    View?
    [ Added: 2015-01-29, 11:16 ]
    [ Added: 2015-01-29, 11:17 ]
    coming back on this issue.
    Living room: HCL mounted on wall, smoke sensor
    Corridor: 1 FGS221 (about 3,5 meters from HCL)
    Office: 1 Smoke Sensor (about 6 meters from HCL and 3,5 meters from mounted FGS221)
    Still got beeps, the FGS221 seems to loose sometimes connection to the HCL..
    Need help!
    /emoticons/default_icon_eek.gif" alt=":shock:" />
    /emoticons/default_icon_question.gif" alt=":?:" />
    [ Added: 2015-01-29, 21:27 ]
    Need definitly help!
    tried to install second FGS221 on the 1st floor. I can see the switch with the first FGS221 installed...hey, but NO Network, could not establish any Connection.
    Used a smoke sensor in range test mode and I can move the smoke sensor in a range about 1 (!) meter from the first Switch, then the green lights turns into yellow, pink.. green, yellow...
    By this way it is impossible for me to extend the Network within the 1st floor.
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    getting mad! NEED HELP!
