Fluorescent flicking
Im using dimmers in on/off switch for fluorescent lamps.. but when i turn off this still flicking.. so i got a test and checked that 55v are sending to lamp.. for this reason the lamp are flicking..
After some search on internet.. i discovered that i need put parameter 10 to 0.. so this still same.. =((
any sugestion ? i need use bypass for each dimmer?
Fluorescent 25w
only one.
Ty!
Bypass or 3-wire setup... Nu guarantees. Dimming fluorescent and LED is... difficult. The forum is full of questions on "what to buy". Ever thought of going for LED strips?
    So,
    i bought a package with some devices.. 8 dimmers, 2 relay switch 2x15,w, 2 rollers.. so i started testing only to see if equips are ok..
    so i used 3 dimmers on currents lights that i have.. only to turn on/off .. i tried search on internet and saw that guys uses dimmers modules to do it. So i tried it.. and got this few "problem"..
    My house is under constrution.. more 3 months to finish it.. so i will start automation.. for now only this issue.. =)
    I can use LED strips.. i will use.. but my house have tons of fluorescent points..
    is 340m2 under constrution.. so i need use on/off switch with fluorescent =))
    is there another device to control it? or i need really use dimmer + bypass ? =)
    Ty,
