Memory usage slowly climbing to 100% version 4.032
Guest bozman
With the new version 4.032 I have seen that memory on my HC2 is slowly climbing from approx. 30% up to 99% in a week..
Is this normal, cpu usage is fine 2-8% when I look...
Is there a way to see what is causing the usage on the memory so much.
Has any one else these problems?
4 answers to this question
Yes I do. They claim it is only the memory that is reserved and can be released if needed. This is due to Linux and is a good thing. The meter just shows the wrong percentage. Fibaro is aware of this.
However we have no idea if it is because of this or because of a memory leak. This fix has yet to be done and it doesn't seem to have high priority (although it is easy to do so).
No way to find out if this usage is an issue...
Guest bozman
    Ok good to know that I'm not alone on this one!
    Like dawiinci said:
    Official statement from Fibaro in:
    Guest bozman
    Thnx for the info.
