Open ports in router /firewall
Hi Folks!
I got my self a webcam and add it to fibaro
It´s a standard AXIS cam ( M1011 )
In Fibaro I set patch
x.x.0.50
/jpg/image.jpg
and every thing function well, then I am inside
But then from the outside I don't get any pictures
My Fibaro has ip x.x.0.30
For the moment I have open port 80 and 23 to x.x.0.30
Witch port and ip address should I open to get pictures ?
Hi Folks!
x.x.0.50
/jpg/image.jpg
On the router redirect the TCP port 80 to the camera fixed IP adress on your lan.
    Well the problem is not that I can access the camera from outside
    I can put camera at example port 81 and open port to it , and it works fine.
    But I can not c it in my fibaro hc2 ...
    At port 80 I have my Fibaro HC2 if I access HC2 from a computer or from my iPhone when I am outside the firewall/router, I can´t see any pictures thru HC2
    Try to change the camera listenig port to 8080 x example ; I think you will solve.
