noor 1
Hello friends , the association and scenes of the door/window sensor is not working at all , I noticed that in door/window advanced -association , group 1 ,2 were empty .
I tried to do the following :-
1- On the set up i tried to add 1 ( Home center 2) in group 1 and 2 manually , but it didn't save any thing.
2-Reload parameters, not solve the problem .
2-I tried to soft reconfigure for door/window sensor ,also didn't change the group 1 ,2 .
3-I tried to full reconfigure for door/window sensor ,same problem.
4- Delete and add door /window sensor several times ,nothing solved.
i attached snapshot for door/window configuration , can anyone help me to solve this problem
note :- i am using HC2 with last version 4.032
