Hi can you pls help - how to create a scene on HCL, which will after triggering set Colour and Dimm the LED string connected to Fibaro RGBW module ?
hi in block scenes for RGBW module you have options to turn on/off, set brightness, R, G , B and W. So first turn on use AND for all the other parameters
i don't think you can choose this with 3.x firmware?
    Not sure whats the block scene is - standard scene, where I select the RGBW as the device ? If yes, than there is no option for R G B W or dimming, only On/Off and some others not nothing of the needed.
    like i said, i don't think you can chose that with firmware 3.xx
    Normally I'd say, search the forum! But the search function here sucks big time, so I won't say it.
    Instead, while waiting for HCL v4:
    Hey Acho. You can create virtual device with few predefinned collor of rgbw and then you can run the scene with this virtual device. So yes, it is possible.
    Thanks for help
