boerremk 84
A scene to use Pushover for push messages.
1. Create global variable: Pushover
2. Create a scene with the following code:
3. Replace the lines user and token with the right values
4. replaces the lines pushTitle, pushMsg, priority and sound with your titles, messages, priority and sound. They must have the same amount of options!
5. You can now trigger it in any scene or VD with the following command:
fibaro:setGlobal("Pushover", "DEVICEID.MSGID");
DEVICEID = ID of the device that initiated the trigger
MSGID = ID of the message you want to show. In my example “Dead node” is 1 and "Battery low" is 2 etc. (id of element in array)
DONT FORGET THE DOT!!!
That is it
8 answers to this question
