Hi guys,
I'm not sure it a bug or not but the RBGW can't change the value show in picture above?
I've reset HC2, add/remove RBGW and it still happen.
Is there anyway to totally reset HC2 + RBGW setting?
Everytime I remove and add the RBGW back, all the preset color is still there and I think it cached somewhere and conflict with the new saving parameter.
Thank you.
[ Added: 2015-01-26, 20:40 ]
Hi, can someone set it use with toggle switch? I just want a toggle light off/on to previous set color value.
It's my controler/rbgw buggy or Fibaro RGBW Controller only able to work with momentary switch?
same problem here!
After 2 days, the toggleswitch function is working, but remote access aint working no more. Even after resetting, no reaction from rgbw controller, main screen, iphone or ipad.
  • 4 weeks later...
Im having similar problems with HCL not setting the parameters correctly. In the log screen at the top it says its sent the parameter but it never changes. So i cant use the RGBW as an interface to my alarm
