Fibaro dimmer - Set Value not working in Graphic Block scene
I'm playing around with Graphic Block scenes and found that for my Fibaro dimmers the "Set Value" option does not work.
See below Graphic Block scene as example;
According to my understanding, this scene would do this:
1. First, the system first checks whether ID 110 is ON and if yes then it should change the dim level to 50%.
2. Then, after 10 seconds, it should change the dim level to 99% and again 10 seconds later it should switch off the light.
Instead, I noticed that the system only switches off the light after 20 seconds and does not change the dim level at all.
Am I doing something wrong or does the "Set Value" option does not work under Graphic Block scenes? Can someone test this, please?
Guest mrzteevee
Same here. Older dimming scenes works but can't change or make a new one. Have also tried with magic scenes but no luck, frustrating....
    Dear Fibaro team,
    I've logged a case in the bugtracker:
    .. can you give us any estimation of when this bug will be resvolved, please?
    Thanks and best regards,
    Mark
