Event panel offline??
I don't get updates over "api/panels/event?last=20&type=id". I checked the event panel and it just started to log again but didn't during the last day.
Also the updates are not available over API...
12 answers to this question
Same issue here, I logged it already 2 weeks ago at fibaro, but have the same issues. After rebooting the HC2 the logs showing again, so it's a bug... again
Guest chaicka
I am experiencing a slight difference. Today is the 5th day after upgrade from 3.600 to 4.032. This morning, there was a period of blank in event log between 10:00+hrs to 15:00+hrs as shown in the screenshot attached (that is when I detect something is not right where a motion-trigger light came on without any motion in its vicinity).
Will log a support case and in bugzilla later.
having the same problem, after some time it stops logging. after rebout it works again.
Guest chaicka
Bug ID #2739
+1 Didn't realize that too. So far only my motion sensor is logging.
PS:
after reboot my netatmo plugin work properly .. for some hours...
bye
Paolino
Looks okay after a reboot, has been down from 22/01 till today.
Guest chaicka
I am still unable to determine the pattern of occurrence as it has been 7 days after the initial occurrence for my environment.
There seems to be no fixed interval (eg. no. of days) when the issue comes up. Now I am trying to determine if the issue has to do with number of events.
Event panel down again. Was okay right after I update to 4.035 at 04/03 and it went dead on 07/03
I had the same problem, but check this,
after i got tempaltes on all my devices it runs smooth again, before 24-25 hours
