XanderF 8
I'm using a minimote to switch on/off lights without a separate/visible switch mounted to the wall. In 3.600 and below I was able to handle all 8 button states with lua, but after upgrading to 4.032 it does not work anymore. None of the 8 cases is triggered.
The minimote is still visible in the HC2 web interfaces, but it does not do anything. Any ideas how to fix it?
%% properties
12 sceneActivation
%% globals
local ButtonPressed = tonumber(fibaro:getValue(12, "sceneActivation"))
if (ButtonPressed == 1) then
fibaro:debug("MiniMote button 1 pressed")
local wallLamp = fibaro:getValue(11, 'value');
if (tonumber(wallLamp) == 0) then
fibaro:call(11, "setValue", 40)
else
fibaro:call(11, "turnOff")
elseif (ButtonPressed == 2) then
fibaro:debug("MiniMote button 2 pressed")
elseif (ButtonPressed == 3) then
fibaro:debug("MiniMote button 3 pressed")
elseif (ButtonPressed == 4) then
fibaro:debug("MiniMote button 4 pressed")
elseif (ButtonPressed == 5) then
fibaro:debug("MiniMote button 5 pressed")
local tableLamp = fibaro:getValue(46, 'value');
if (tonumber(tableLamp) == 0) then
fibaro:call(46, 'turnOn')
else
fibaro:call(46, 'turnOff')
elseif (ButtonPressed == 6) then
fibaro:debug("MiniMote button 6 pressed")
elseif (ButtonPressed == 7) then
fibaro:debug("MiniMote button 7 pressed")
elseif (ButtonPressed == 8) then
fibaro:debug("MiniMote button 8 pressed")
else
fibaro:debug("No response")
4 answers to this question
