Dcd971 0
Hi forum users,
I am having trouble to synch the status of my Leviton wall switches/dimmers with HC2. I can control them via HC2 without a problem and when I do so, HC2 status for that switch matches the real life on/off status. However when I locally switch on or off, I don't see the updated status in HC2. I am on 4.032.
Prior to Fibaro, I was on Leviton's own controller stick and then with Vera and I did not have this problem.
Any ideas why this might be happening and how I can synch the status between HC2 and the actual switch?
Here is a link to the switch/dimmer that I am using.
Thanks in advance...
