How to set Horstmann SRT321 from LUA?
Hi all,
I'm struggling a bit with the following:
When using LUA to set my Danfoss thermostats, I use setTargetLevel and add the temperature.
fibaro:call(98, "setTargetLevel", "21")
When setting the Horstmann/Secure SRT321, it takes 2 parameters, but I'm unable to find any information about what of the 2 is what. I suppose, one of the two is temperature, the other is duration, but when trying it out, the results are quite inconclusive.
fibaro:call(218, "setThermostatSetpoint", "21", "2")
fibaro:call(218, "setThermostatSetpoint", "2", "21")
appear to have the same result: set temp to 21 degrees. Same difference?
I had to switch from Heating Panel to Lua, since my SRT321 would revert to the heating panel settings after a minute (which is according to specs, so not an error) when set manually to a different setting. So, setting it up in a Heating Panel is obviously not a workable alternative for me.
Any suggestions?
Regards!
- update: Just sent an inquiry about this to Horstmann in the UK.
    Hi all,
    So far I have come up with the following:
    This gives the following results:
    [DEBUG] 01:42:24: 17
    [DEBUG] 01:42:24: 19
    [DEBUG] 01:42:24: 01:42
    [DEBUG] 01:42:24: 0
    [DEBUG] 01:42:24: WAITING_FOR_WAKEUP_TO_CONFIGURE
    This leads to 2 conclusions, for now:
    • 1. The timestamp differs from the Danfoss: in Danfoss it gives you the END time of the targetvalue you set; in SRT321 it is the moment it got the command to set the setpoint.
      2. The second parameter you give in the setThermostatSetpoint is the actual setpoint. Still no clue what the first one does, though. The only thing I can see is that it messes with the moment it sets the setpoint whenever it differs from the second parameter. In other words: when you set it as "21", "21", it switches to 21 as soon as it wakes up. Set it as "19", "21" or any different value, the SRT321 will take forever to wake up. Don't know how long, but (much) longer than the normal 300s.
    Any additions are welcome, people!
    For the time being, I will use this format:
    This will give you no control over the length of the heating period, like the Danfoss does when you use
    so you will have to control the heating period yourself.
    (The Danfoss will run for 2 hrs on 21 degrees Celsius, before returning to the previous setpoint (look at "value" before Danfoss sets the new value).)
    Regards.
    [ Added: 2015-01-31, 22:37 ]
    Hi all,
    It seems that
    Works just as well.....saves the trouble of figuring out the parameters of the other command.
    Bonus: it switches with the interval of 300s, so within 5 mins.
    I think I leave it at this, since the SRT321 doesn't accept time settings. It depends solely on you to program the timing right in the HC.
    Regards!
