Help with lua code
Hi all,
I'm new to Fibaro and I'm not a coder, on top of this I no nothing about lua. However I have searched the forums/web trying to find a solution for sending the value of one of my temperature sensors to my old external automation controller variable number 242. Below is the code I cobbled together (I have to say I don't totally understand the code).
When the code is run it returns the following error -
[ERROR] 09:42:43: line 10: unexpected symbol near '242'
Can some help with debugging this please?
Many thanks
Steve
4 answers to this question
check line
and remove ":"
    check line
    and remove ":"
    Thank you for your reply, I removed the colon as requested
    and now get this error -
    [ERROR] 10:28:22: line 10: unexpected symbol near '242'
    your line
    is wrong
    try with
    or
    You can't end the line with "," and Var 242 can not work
    your line
    is wrong
    try with
    or
    No still no good. However this code works -
    It updates variable 242 with the temperature ok and actions a macro on my remote controller with ID 251. If I remove the macro part of the syntax I get the errors. How do I remove the macro part of this code?
    This also works -
    local postdata = "Var 242 : " .. temp1 .. "=="
    Not sure what the "==" is for though? If anyone can explain that would be appreciated.
