About consumption watts
magao
Hi everyone,
Does all devices(dimmer,relay,etc..) have valueMeter ? And hows it work ?
Im doing some lua scripts to my new home ^^
Thank you!
4 answers to this question
Maybe this post is interesting for you:
What you can do for example is run through all the Fibaro devices, and check for the interface "power". If a device supports the power interface, you can read it's current power consumption.
Note that the code above is part of another code, so it's just to give you an idea.
The interface "energy" lets you read the cumulative energy consumption (I assume, never used that myself though).
For V 3.X use valueSensor
For V 4.X use power
The change to property "power" is not documented afaik.
The Fibaro Wall Plug has it...
  • Thank you for answers!
    But I was thinking that all devices has "power" property..
    Will be great if this occurs.. Because I can control and make some decisions
