Possible to show LUA-code of a block-based scene?
Hi together,
If I have some scenes that are block-based is it anyhow possible to see the LUA code behind? (for learning reasons) Could I see the code if I would switch to LUA after creating a scene with blocks?
thanks and cheers,
alkorsi
Hi, on v4:
In advanced there is a button to convert to LUA. Once clicked you can preview the code and decide if you want to convert permanently.
alkorsi, yes if you are using hc2. HCL does not support lua.
