How I get the selected icon of a relay switch with LUA?
how I get the selected icon of a relay switch with LUA?
1. the icon when the contact is closed
2. the icon if the contact is open
local icon = fibaro:getValue(deviceID, "deviceIcon")
fibaro:debug(icon)
With this LUA script I only get one ID; likely when the contact is open.
16 answers to this question
AlexanderRi, you should check the status and not the icon
0 = Off
1 = On
Krikroff,
/emoticons/default_laugh.png" alt=":lol:" />
    Krikroff, no your query I know.
    For my LUA script I really need the ID of the icons.
    Do you have a solution?
    Maby you can use a part of my lua below.
    no one has a solution?
    Again, what I'm looking for:
    For the relay switch module I MANUALLY selected main icon (from FIBARO) for ON and OFF.
    Now I want to retrieve the ID with LUA for these two icons, which I have set manually.
    I tested the following LUA script:
    fibaro:debug(icon)
    But I only get one ID for ON and OFF, not two different values.
    And the following LUA script always returns nil:
    local icon = fibaro:getValue(deviceID, "currentIcon"
    Has anyone a solution?
    If you want state you must watch for value
    deviceIcon is resource that show package  of icons
    List of icons pacage you can get from there
    This variant (
    ) I know. But I want it to read with LUA!
    If I manually change the icon, I have just with LUA the current value and does not need manual intervention.
    A solution with LUA?
    i try to change the propertie "deviceIcon": "2"
    i use a PUT request but i can't change the number of the used icon.
    Is it possible to change that propertie ?
    Are you trying to change ID of a icon with ID == 2? System icons cannot be deleted or changed.
    Thank you for your reply, in fact i try to change the icon of one device with his json properties.
    This scene works for me just fine, please give it a try.
    Thank it's work fine but it's in a scene
    Can i do the same in a button of Virtual Device ?
    It is even shorter:
    Thank you, i made a mistake with two ""
    Generally you can use " or ' if you wish, but sometimes you need to combine them like in 2nd line.
    I try to change "ip" or "port" properties but that don't work ....
    Is it possbile to change every properties in a json ?
