Great I see Fibaro have released a new controller in Sweden
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />!
FGS212 2.5kW.
FGS222 1,5kw x 2
Whats the difference between them and the old ones?
And are they now approved by the authority "Elsakerhetsverket" ?
Or maybe they are exactly the same with a different model number and as such are not banned, yet. I would have expected a little bit of a song and dance from Fibaro is the problems were resolved given the high profile nature of the ban, here on the forums anyway.
    Fibaro can you give us some answers please
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />?
    Whats the deal with the new version?
    1. The main reason was wrong distance between the live parts 1.6mm when required is 3.0mm.
    2. The insulation distance. The measured distance was 1.8 mm where the requirement is likewise 3.0 mm.
    3.The labeling was wrong 16A when its made for 10A.
    The most important thing is that issue 1,2 is fixed, can you confirm this Fibaro?
    Kumlaekeby, Where did You get this information from?
    Guest GG
    The new modules are called
    FGS212 - 1x2,5kW
    FGS222 - 2x1,5kW
    There you have some Swedish links.
    So now I want some answers what have been fixed
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />. FIBAROOOOO????
