Fibaro Fireplace
Guest jpaternina
Hello guys! i was wondering if you would help me to control my gas fireplace using Fibaro. I was thinking on controlling the spark with the relay module Fibaro relay 3kW but it would works to turn on the fireplace but i'm not pretty sure yet about how would i turn it off? Please help me, i am stuck, thanks in advance!!
This is a dangerous idea! You probably don't want to try that! You need to have the gas valve open all the time and have a fibaro rgbw or shutter unit to control a separate gas valve. A dead node could cause more than some curses in that case.
/emoticons/default_icon_exclaim.gif" alt=":!:" /> again don't try this with a z wave solution!
I have a appointment soon with a supplier of these universal remote systems. We're gonna check if I can make a connection with Fibaro.
Keep you posted
Guest jpaternina
    Keep you posted
    Thanks Tricky please let me know if you got something.
    Best regards
    We have a new contender for the Darwin awards here!!
    What kind of controller does your fireplace use? My fireplace uses a Mertik controller and I use 3 Fibaro relays to control the fireplace. I needed a special cable to connect to the Mertik.
    Guest jpaternina
    Thanks for your reply boerremk. Please tell me if you added this controller to your fireplace or it just come with it. If so, please tell me where can i get this controller. Do you mind give me and schema of the connection of the 3 fibaro relays? Thanks in advance!
    The controller came with the fireplace, but this model is used by a lot of companies. I will provide the schema this weekend.
    • 6 months later...
    @Boerremk
    Do you have the details on how you connected the Mertik to fibaro and what relays you did use?
    Attached the schema.
    • 3 years later...
    hi boerremk,
    Could you explain a bit more about your schematic?
    I also noticed you blue/neutral is connected to "I" and not "N"
    Like to hear from you!
    Regards
    Martijn
