Fibaro FGR221 Roller Shutter Calibration in Scene
Hi all,
Fairly new to Lua so maybe a stupid question but I couldn't find it anywhere on the forum.
Is there a way to calibrate FGRM-222 from Lua?  (FGRM-222 and not FGR-221 as stated in topic
/emoticons/default_icon_redface.gif" alt=":oops:" /> )
Or how to set a parameter (in this case 29) to 1 in Lua?
I'm using FGRM-222 to control mixing valves for the central heating
and since there is lots of small movements up and down
and motors take 1 or 2 minutes to fully open or close
the things get out of sync after few days.
So I want to run a script in the middle of the night to recalibrate all mixing velves.
(3 mixing valves 2min, 1 mixing valve 1min, and 2 3pot valves)
Many thanks
Edo
4 answers to this question
    Sure.
    I have only 5. So I created 5 button Virtual Device.
    Button 1 - 5
    Create 13 buttons (or one could do it with a loop), just change "id":511, to your roller shutter v2 id.
    You can use LUA script to press the buttons at requested time.
    Edo
    Figured it out with VD.
    {"id":512,"properties":{"parameters":[{"id":29,"lastSetValue":0,"size":1,"value":1}]}}
    Could you maybe share a sample lua line to trigger calibration of roller shutter v2? My 13 modules get messed almost weekly and manual calibration is pain in the ass.
    Thanks in advance
    Great! Thanks a lot! I have now one button VD to calibrate all roller shutters at once
    /emoticons/default_icon_smile.gif" alt=":-)" /> And hopefully will be able to trigger it from scheduler weekly or similar.
