Temperature in event panel is x100
All temperature notifications in the event panel are 100 times too large. 5,46 degrees is displayed as 546. 12,36 as 1236 etc. Version 4.0.32 didn't have that issue.
4 answers to this question
    Example:
    Does anyone has the same problem?
    Bug reported and marked as fixed in next release:
    Where are the support?
    Issue
     says that it's fixed in the next release of the HC2 firmware, to me that means 4.034. So I doubt support will be able to help you right now...
    Do you have an issue that is not covered by this bug report?
