You don't seem to support any manufacturer info either. This is NOT good, Fibaro. Don't show me any error messages, when I can't do anything, not even manually.
Please implement support for Z-Wave SwiidInter Cord Switch in your next hotfix. I'm using v 4.033 at the moment.
joamlin 4
I bought one of these yesterday: http://www.vesternet.com/z-wave-swiidinter-cord-switch.
The device works as intended, BUT my system thinks otherwise, see attached images.
I've tried to remove/readd/reconfigure - no difference. HC2 has been restarted.I've tried to add parameters manually, but that doesn't work either.
You can find the parameters here: http://www.swiid.com/medias/documents/advanced-swiidinter.pdf
Link to post
