Stealth 10
I'm having an issue with getting the Heating Panel to work!
I have the following modules -
1) Fibaro Universal Module FGBS-001
2) Fibaro FGS-211 Relay Module
3) Dallas DS8b20 Temperature sensor
I want to use these parts as a thermostat to control my hot water boiler. (i.e. temperature sensor on the hot water tank, when temperature drops below a threshold (between certain times of the day) the relay will answer the call for heat at the boiler by switching it on)
I have added these modules to the HC2 but I am having problems trying to get them to be controlled by the heating panel.
This is what I have done -
a) I put the temperature sensor and the relay in a room named 'Water Tank'
b) I have linked the temperature sensor and relay in the linked devices panel and named it Linked Hot Water
c) I created a zone in the heating panel named 'Heat Control' then added the room 'Water Tank' to it
d) I then set the temperature required with the day and time in the 'Heat Control' zone panel.
But when the water temperature drops below the threshold set the relay won't switch on.
What have I missed?
