Lilli configuration
could someone give me a hint on how to properly trigger a device with Lilli?
What i did:
I installed a fibaro relay switch and set the Lilli Command to switch on (in german, is that possible?): "Licht an" or should that rather be "Light on"?
I reloaded the Lilli Database
I took my iphone with the latest app, hit Lilli, and the Lilli Button and said "licht an"... no response...
Is German supported anyway?
Cheers
joystick
5 answers to this question
I´m not so familiar with Lili, but as fas as I know it has to be an english command like "light on" AND every command has to be written without capital letters (i.e. Light On). After defining your commands, you have to reload Lili´s database (under configuration)....
No german support. You have to make a english command as jojo1967 say
OK.. So I have setup my table lamp with the command "lamp off" and Lili seems to understand the command as it shows on the screen. But then it does not do anything and just keeps saying "I didn't get it. Could you repeat"..
Does this really work??
try some easier command at first. check what lili is getting what you are saying and adjust the command from there.
I've tried one, lili heard it as want.
Guys, Lili works for me even in slovak language, I only need to write the command in slovak and use Slovak language as main language for voice commands in google now. Simple and works
