Guest chaicka
Isn't that just the EN14604 compliant Smoke Detector?
The xml file mentioned "zwaveplusversion" in one of the parameters, hence wondering if it is the first z-wave plus module Fibaro has release. The module is also not available in all locations yet.
    Update:
    This IS NOT the first zwave plus device from Fibaro.
    According to a few webshops it is zwave plus, but the documentation states is still zwave (1)..
    Manual:
    Webshops...
    See
    And:
    It wouldn't make sense to release a zwave plus device without having a controller based on zwave plus..
    Easy, i'm a positive guy! and this topic is about z-wave plus..., why RFXCOM?
    The point being, they are way behind there competitors in everything else, why would you expect them to be ahead with Zwave Plus?
    I can confirm this is not Zwave plus, however not sure if Fibaro are trying to pull a fast one with there dodgy marketing. Why in your right mind would you call a device Plus when its not Z-Wave Plus, it feels as if Fibaro are trying to fool people into thinking its a Zwave Plus device, which would be perfectly in keeping with all there other bogus marketing.
    Again proving Fibaro are behind almost every Hardware manufacturer. I don't know of many other z-wave manufacturers that don't have some Z-Wave Plus / Gen 5 hardware already on the market
