Hello guys;
I guess i have this diagram in my house. I want to connect double relay for universal dimmer (so i won't use the neutral) .
This is a 2-way switch. Will you please tell me how to connect it?
You should replace the the switches with push-button (monostable) switches.
You'll have to pick one of the setups described here:
Are you planning on using dimmable LED or CFL? Then I strongly advice a 3-wire setup. And always do some testing. A 2-wire + bypass may work. In any case, if you are not familiar with the dimming behavior of a CFL or LED, then I must warn you that you may be disappointed. So, if you're not going to use dimmable lights, I would use a relay... This is my personal opinion, other forum members may disagree.
