I have noticed that many events that I know have occurred (motion sensors breached, switches changed state etc) do not show in the event panel.   Does anybody know what causes this?  I am using 4.032.
I had the problem on 4.032 but for me it's ok in 4.033
Had the same issue in 4.032, not in 4.033
4.033 here, event panel not working.
Location panel as well.
My the log works properly only for a some days after that no message are available in panel console.
I use 4.033.
  • 4 weeks later...
My event panel stops registering events out of the blue yesterday at 15:43h.
Can I do a clean up of this log ?
Seems to be working perfectly after updating to 4.035.
I have installed 4.035 2 days ago. I had this issue before and still after the upgrade.
If this problem occurs because of the huge log-table I propose to initiate a configuration setting in whitch we can limit the log-history ( eg 1 day...) or a procedure to clean-up the history.
During scrolling down true the log I saw a message of a ¨new event¨ appearing on the screen.
By scrolling up to the top I've found the event, just before the last one of yesterday. After pushing the ¨show¨ button, it disappears again and could not be found anymore.
I think it is a gui-problem.
Please Fibaro Can you look at it ? It is annoying during configuration of the system or by analysing why some scenes in LUA aren not doing what is proposed (due to wrong programming)
I have problem with the location panel too. I am running 4.035.
Event panel down again. Was okay right after I update to 4.035 at 04/03 and it went dead on 07/03
I had the same problem, but check this,
after i got tempaltes on all my devices it runs smooth again, before 24-25 hours
