StellaZ Thermostatic compatibility Fibaro?
hello can you tell me if they are compatible the
StellaZ Thermostatic valve   with HCL?
StellaZ is not compatible with V3 of the HomeCenter firmware (I've tried it). And V4 isn't available for HCL yet (assuming StellaZ would work with V4, but I doubt that)... So the short answer is: not compatible.
Why would you choos stellaz over danfoss? They are real ugly and make horrible noise when working.... I recommend you danfoss any time.
    Star because they also give the room temperature Danfoss no ..... anyway thanks for the advice if they are noisy take the Danfoss
