Hi this is my first post!
For a long time now I have been trying to get my HCL to send a string to my Raspberry Pi running Domoticz, I have managed to get weather and other devices to feed into the HCL but cannot get the HCL to control lights when setting up a virtual device.
Can anyone help me, if I put the below into IE I can turn the light On:
If I put the below string into HCL under a virtual device nothing happens:
GET /json.htm?type=command&param=switchlight&idx=25&switchcmd=On&level=00x0D0x0A
What I want to be able to do is control my LightwaveRF devices from my HCL.
All the LightwaveRF devices are working on Domoticz on the Raspberry Pi
Could anyone tell me what I am doing wrong?
Many thanks
Vince
12 answers to this question
    Can anyone help with this?
    Cheers
    Vince
    And if you try it like this:
    Hi I've tried it that way works fine if I paste into Internet Explore/chrome etc.
    Nothing happens when I put into HCL
    Exactly my problem ...
    Would love to find out how to PUT JSON Data from a virtual device
    Still haven't managed to get this working
    hello
    so i think that the fibaro link under domoticz setting is only for data from Domoticz to Fibaro? i ask this because i found this post at the end of my search about info for controll philips hue light that i have correctly installed on domoticz, from a fibaro HCL.
    any chanche? thanks
    after test i see that my hcl every time that i put the correct json string, when i push save button, the system change it !
    this is the reason because not function.
    example:
    i put in the on button of the virtual device the correct json string:
    command&param=switchlight&idx=17&switchcmd=On&level=0
    after pushed save , the systen change it in:
    command¶m=switchlight&idx=17&switchcmd=On&level=0
    And now? how we can fix it?
    Many thanks
    Vince
    don't use
    but:
    GET /json.htm?type=command&dparam=switchlight&idx=25&switchcmd=On&level=HTTP/1.10x0D0x0A0x0D0x0A
    Thanks for the reply I have tried the above and again works fine from Internet Explorer but when put in HCL nothing happens.
    I am facing the same issue - i.e. the string works in Internet Explorer but not within a Virtual Device in an HCL.  Did anyone get an answer to this?
    IGNORE - I worked in out.....
    thanks
    Edited by sitaylor
    I have a virtual switch in fibaro and a normal switch in domoticz. (on/off)
    I use the virtual switch to set the switch in domoticz on or off
    And i use this for switch on.     GET /json.htm?type=command&param=switchlight&idx=133&switchcmd=On HTTP/1.10x0D0x0A0x0D0x0A
    And this for switch off . GET /json.htm?type=command&param=switchlight&idx=133&switchcmd=Off HTTP/1.10x0D0x0A0x0D0x0A
    And ik works for me.
    Rob
    Can someone please advise whether it is possible to manage multiple switches in the same String?
    For 1 switch, this works fine (as outlined by others above):
    GET /json.htm?type=command&param=switchlight&idx=13&switchcmd=Off HTTP/1.10x0D0x0A0x0D0x0A
    But how to do multiple switches at the same time?, ie:
    GET /json.htm?type=command&param=switchlight&idx=14&switchcmd=Off
    GET /json.htm?type=command&param=switchlight&idx=15&switchcmd=Off
    or
    GET /json.htm?type=command&param=switchlight&idx=13,14,15&switchcmd=Off
    thanks
