FGS221 doesn't react on association from FGS211
I have an FGS211 that I'm trying to set up for association for group 2 to control one part of an FGS221 which doesn't work. If I change the association group 2 to control another FGS211 it works fine and so does other switches like a wall plug or a TKB switch. It seems association with the FGS221 is the only thing which doesn't work.
Anybody have any ideas what could be the reason?
Thx/U
Guest spazpeker
you can only do it with the primary relay not the secondary relay
    Ah, didn't know that. I thought it reacted like any other device on association commands. Simply switching positions will make it work then.
    Great, thanks a lot!
    Guest spazpeker
    yes had to swap mine
    Swap done and now it works perfectly. Thanks!
