Dimmer set load value, but not turn it on yet
Hi guys,
is there a way i can set the value of the dimmer in code, but not turn it on yet ?
Like the same parameter that hold the value the dimmer had before it was turned of?
Robert
No.
I kew I'd read it somewhere... The information is not recent but worth a try.
At the moment I use a script that looks rather complicated, so I won't post it here... But the key is it runs this at a certain time:
fibaro:call(DimmerID, "setValue", DimLevel)
fibaro:call(DimmerID, "turnOff")
And... Yes... You'll notice a (small) flash of light
