Is it possible to customize user interface in smartphone application and PC interface, like adding building layout and get preview of which all lights running in rooms, over all view - like in the attached picture.
No, not possible... But you can Build your own application and Check the status via the api
    Thank you. Which is the tool used for creating applications?
    He means that you can build a whole application from scratch. Which means that you need some knowledge about programming.
    Yes, there is no other solution...
    • 4 weeks later...
     Or if you have some webserver / php skills .. this may help you :
    Cheers,
    al.
    • 4 weeks later...
    I haven't had time to work on my interface for some time now, but this is what I've got as far as room overview goes... It isn't completely polished yet, but I am still working on it when I can find a bit of time for it, but it is slower progress than I thought...
