Can t recovery
Guest Bobby
Guest Bobby
Hello everyone,
I have a problem when I want to recovery.
I press the + button and power, then LEDs starts from the left, and then all LED are on.
I can't acces the HC2.
I tried many times.
Can you help me ?
v4.033
4 answers to this question
Chances are that nobody can help you, except Fibaro support. I've seen a few reports of this and I had a similar case.
They'll probably ask you to attach a monitor to your HC2 to see what it has to say at boot time. If it's all black, than the box needs to be repaired.
Could you try that, please?
Guest Bobby
    Thank you for your reply Peter, and sorry for my bad english. Hope you will understand.
    I attach a monitor to my HC2 and try to make a recovery.
    It is not black, but I can't exactly tell you what it says...
    It is writing during 3-4 minutes and then become black.
    When I boot in working mode, the verify checksum seems looping (Config/Backup&recovery/Recovery).
    Maybe my recovery partition have a problem?
    No need to apologize, your English is all right
    Yes, I was thinking corrupted recovery partition too... I've seen the "checksum" function in the web interface, but I didn't notice it on the boot screen. It has been some time ago that I attached a monitor to my HC2, mayby it scrolled by very fast or it wasn't there yet.
    In any case... Bad news ...
    /emoticons/default_icon_sad.gif" alt=":-(" /> It sounds like an issue for Fibaro support, because I've never seen anything on this forum to fix this type of problem. Probably they'll ask you to send the box in for repair.
    Guest Bobby
    You're right Peter, it is in the web interface that the verify checksum is looping.
    I will send an email to fibaro support.
    Thank you for your help.
