HCL Virtuel Device - PUT REST Command not working
maybe some here could help.
I have a HCL (3.593) and want to simply switch on/off a hue lamp via virtual device.
The only importable ready Phillips Hue Virtual Devices i could find on the internet are with LUA for HC2, so i tried to create a very simple one for HCL
I could test the HUE API commands via the debugging console of the HUE bridge. (
I created a User "0123456789abdcef0123456789abcdef" and i can simply turn the light on and off via this simple PUT Command via the Debug Console (that works)
PUT /api/0123456789abdcef0123456789abcdef/lights/1/state (URL)
{"on":false} (Message Body)
So i tried some code for the button in die vd, but none worked ... someone here to help me finding my mistake?
Some examples, that didn't worked:
I have this same issue on 4.100....
I do the some without any result
POST /upnp/control/CIS
Content-Type: text/xmlx0D0x0A
SOAPAction: "urn:schemas-sony-com:service:X_CIS:1#X_CIS_Command"x0D0x0Ax0D0x0A
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:X_CIS_Command xmlns:u="urn:schemas-sony-com:service:X_CIS:1"><CISDATA>0204A0600001FB</CISDATA></u:X_CIS_Command></s:Body></s:Envelope>
This was supposed to work but it doesn't
