I would like to use 2 different ventilator speeds of the mechanical fan. This is done by having power on either 2 or 3 of the perplex connection. They can't have both power on them.
Can the roller shutter 2 do this trick?? Problem is that a roller shutter always stops, how could I prevent this from happening if I want to use a roller shutter 2 for the mechanical fan??
I can't figure out the lua parameters and their values....
thanks!
emiel
It shouldn't be that difficult.
Par. 10: Roller blind positioning inactive.
Par. 14: depend how you want to control it with switch(es)
Par. 18: You could set it to 0W or 1W so it should ignore it. (it will turn it Off if you have switch after Fibaro)
  Otherwise see how much power the fan is using on the fast speed.
  and put is slightly higher so if your hair or something else get tangled in the fan, the motor should require more power and Fibaro would stop it.
  So you have another safety feature.
Par. 22: For continuous operation you can set it to 0
  Otherwise you can set time from 1s - ~18.2hours, after which the fan will be automatically turned Off.
So on the computer or the phone you would use Down - for slow, Up - for fast and Pause for stooping.
I think that's it.
Haven't try it myself but from my experience with Roller shutter 2 it should work. If not let me know maybe I missed somethung.
Edo
    hi Edo,
    thanks, works perfect!
    cheers
    emiel
