I have an external blind I with a scooter Shutter2 steer with full functionalities, eg Slats open and shut.
Now I needed a master switch for the blind, because I took a normal Roller shutter button of Jung and a Fibaro dimmer.
The connections were implemented using a scene then when pressed the shutter A high and runs from the blinds down.
But I was lost now to the states Stop and slats and but for this I need yet.
The stop function I halfway solved with LUA.
while I have but the double on the dimmer is not activated because Simple and double at S2 did not work.
Now works with the LUA script and double off the button like this:
- Long S1 blinds are high again briefly S1 blind Stops
- Change from S1 to S2 blind Stops
- Long S2 blind moves down again briefly S2 blind Stops
Now I am in need of help I do not get on.
Is there a way to adjust the dimmer so he can inherit all features of a scooter or Shutter2 can learn to take it as an alternative?
Or is there a way that better gestallten with LUA?
Maybe even a 2nd scooter Shutter2 is more suitable only I do not know how I should connect it with the blind since he is in addition to and with no cable is connected to the blind.
Thank You.
