Does anybody have the Philips Hue VD vfib file, I can´t find it in this forum.
Does anybody got the Philips Hue plugin to work, I can see my lights but nothing happen when i´m pressing the buttons.
Help is highly appreciated.
5 answers to this question
Rydberg, try to reinstall the plugin and try a few times. With my HC2 it works fine but I had to try a few times....
here...
here...
Camar, thanks for posting the VD.
One question: which port is normally used to contact the Philips box ?
Id like to add into VD into Main Loop a code checking if the HUE is ON or OFF - can you pls help me with the code ? ( Id like to use it to set VD icon based on it ) ?
Thanks a lot
here...
Is there a special way to unwrap or convert these VD's? I get an "Illegal file format" error for both when installing them on a HCL 4.0.44
tnx
